DIAdem
CFP 2200 and diadem
how to connect the CFP 2200 with diadem opcfildpoint server is not starting
(4,040 Views)
can you please describe what you have tried to do to connect the cFP 2200 with the server?
Thanks a lot!
(3,960 Views)
Maybe the following links can be of some help:
Troubleshooting Communication Problems with the FieldPoint Ethernet Network Modules
http://zone.ni.com/devzone/cda/tut/p/id/4368
Unable to Locate an Ethernet FieldPoint Network Module in MAX (or FieldPoint Explorer) in Windows XP
http://digital.ni.com/public.nsf/allkb/0B043CFE88E055EF86256E600074F751?OpenDocument
If the FP is configured correctly make sure that the ika-file is saved. More info's see next links:
FieldPoint Installation/Configuration
http://www.ni.com/support/fieldpoint/fpenet.htm
What Is the Relationship Between .iak Files, the Project and MAX?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kGgPSAU&l=en-US
(3,892 Views)
Hello herry_p,
Do you still have a problem with the OPC-server? If the server is working well, does the communication between DIAdem and the OPC-Server work fine too?
Greetings
Walter
(3,839 Views)
