DIAdem
CHN COMBOBOX CHANNELS ASSIGNMENT
How do I use the channels selected in the combobox or chncombobox inside the TDR report.
How do I assign the channels selected in the combobox or chncombobox to a new variable name.
Difference between combobox and chncombobox.
X. Ignatius
Message 1 of 9
(7,579 Views)
Hi Igni,
The chncombobox automatically shows all the channels that happen to be in the Data Portal at the moment.
The combobox shows only the texts that you intentionally add to it.
Please clarify the rest of your question,
Brad Turpin
Message 2 of 9
(7,551 Views)
Dear Bradin,
Is it possible to draw a 2 d XY graph by selecting X channel in one chncombobox and Y channel in another chncombobox. Could you explain with an example script.
X. Ignatius
Message 3 of 9
(7,533 Views)
Dear Bradin,
X. Ignatius
Message 4 of 9
(7,533 Views)
Hi X. Ignatius,
Yes, that can work just fine.  You'll need a button on the SUDialog to cause VBScript code to run that reads the X and Y channel paths from the ChnComboBoxes and assigns them to the curve configuration of a particular graph in REPORT.
If you'll send me your *.sud and *.tdr files, I can provide the code to make that happen.
Are you using DIAdem 2012 or an earlier version?  The functions to do this changed in DIAdem 2012.
Brad Turpin
Message 5 of 9
(7,521 Views)
Dear Brad,
Pls find the attached files containing .sud, .tdr and .vbs.
Request you to modify to suit my requirement.
Thanks and Regards,
X. Ignatius
Message 6 of 9
(7,346 Views)
Dear Brad,
Attachment missed in previous text.
X. Ignatius
Message 7 of 9
(7,343 Views)
Accepted by Igni
Hi Igni,
These changes in your SUDialog appear to do the trick on my end.
Sub Button1_EventClick(ByRef This) 'Created Event Handler
  Call PicDelete()
  Call PicLoad(CurrentScriptPath & "XY.tdr")
  PicDefByIdent = 1 ' Name-Oriented channel referencing
  Call GRAPHObjOpen("2DAxis1")
    Call GRAPHObjOpen("2DObj1_Curve1")
      D2CChnXName = XSelection.Text
      D2CChnYName = YSelection.Text
    Call GRAPHObjClose("2DObj1_Curve1")
  Call GRAPHObjClose("2DAxis1")
  Call PicUpdate()
  Dialog.Cancel()
End Sub
Brad Turpin
Message 8 of 9
(7,103 Views)
Thank you very much Brad.
It works.
X. Ignatius
Message 9 of 9
(7,090 Views)
