DIAdem
/CScriptStart
When I run one script with one .exe with the command:
"D:\Archivos de programa\National Instruments\DIAdem 10.2\Diadem.exe" "/CT1:='xyz'" "/CScriptStart('C:\Documents and Settings\...\IDIADA DynAsoft.vbs')"
The script runs very very slow, more than if I open Diadem manually and I runs the script by F5.
I used Diadem 10.2, but if I used Diadem 11.0 the script runs slowly too, but not as much as Diadem 10.2
How I can fix this? Because I need to run with the .exe.
(4,817 Views)
Hello !!
I found that the problem of slow comming by this code:
Set ws = CreateObject("WScript.Shell")
If FileExist(AutoDrvUser&"XXX.exe") Then
Set VarApp = ws.Exec(AutoDrvUser & "XXX.exe")
   While VarApp.Status=0
     Call Pause()
    Wend
Call Pause()
Wend
End If
If VarApp.Status=0 then..
What Can I do?
(4,812 Views)
Hi s.g.m.,
Hmmm, I haven't tried that particular Windows Shell method to run external *.exe programs.  Usually if you're running a DIAdem VBScript and you want to run an external program, you use the "ExtProgram()" command.  You can also use the "FilExist()" function to check if the *.exe" is present first.  I've also had good luck with the Windows Shell method "Run".
Please give that a try and let me know if it runs faster,
Brad Turpin
(4,798 Views)
Hello Brad,
thank you for the question but I have one question, what is the way to control when program is finish?
(4,786 Views)
Accepted by s.g.m.
Hello Brad,
I've solved the problem, I implemented a function that returns if XXX.exe is still running in task list of windows.
The function ExtProgram()  run Diadem faster than the other function. I don't have problems now!
Thanks!!:
(4,779 Views)
