DIAdem
Calculate individual channel values in absolute terms
I have a question and I would like to calculate the individual values of a channel line by line.
Here is an example:
Line Channel 1 ABS calculated
1 0 0
2 5 5
3 5 0
4 10 5
5 -10 20
6 0 10
Row 1 minus row 2 is calculated absolutely, the result in column ABS calculated in row 2 is therefore 5.
The same with row 2 minus row 3, in column ABS calculated in row 3 again the new value 0.
The whole thing continues row by row, of course. In Excel, this would be the classic formula =ABS(A1-A2) and simply copy this down for each additional row. How could I make this possible here in Diadem? I haven't found anything suitable yet. Maybe someone can help me?
Many thanks and best regards
(704 Views)
There are different approaches. You can write a script like that:
dim i, objChn
set objChn = Data.Root.ChannelGroups(1).Channels
Call objChn.Add("Channel 2", DataTypeFloat64)
for i = 2 to objChn("Channel 1").Size
  objChn("Channel 2").Values(i) = abs(objChn("Channel 1").Values(i) - objChn("Channel 1").Values(i - 1))
next
or use the channel function "calculate differences" and afterwards calculate the absolute value of the result channel using the calculator:
ch("[1]/Delta") = abs(ch("[1]/Delta"))
Holger Müller
DIAdem experience since 1996
Turn-key applications - Remote and on-site trainings - On-the-job training
| müller+krahmer GmbH | Koenitzer Straße 14, 07338 Kaulsdorf / Germany |
| Phone: +49 36733 / 2328 - 6 | Mobile: +49 160 / 287 7294 |
| Email: mueller@mueller-krahmer.de | Web: www.mueller-krahmer.de |
(666 Views)
You can write a script:
dim i, objChn
next
Or you can use the "calculate differences" function in ANALYSIS and the calculate the absolute values using the Calculator:
Holger Müller
(666 Views)
