DIAdem
Failing to load DATA From ODS6 server AOP6 Plugin
so i have tried to connect to an ODS6 server with the Aop6 (19.0) Plugin which is successfully connecting and i am able to see the channel data and attributes in the preview but as soon as i want to load the data to the Dataportal, DIAdem either does not respond or when i drag&drop a measurement into the Dataportal it will show me only the " General Error with Command Storageimport" and that it. No further error messages in the Plugin or DIAdem.
Also i noticed that the Loadingparameters for that datastore is empty and if i want to edit it DIAdem crashes.
has anyone expercienced the same or can give me a hint where to look at or how i can increase DIAdem Logging to see where the issue comes from ?
Help very much appreciated!
Thanks in Advance!
(763 Views)
Does nobody have any idea how to approach this issue?
(692 Views)
Maybe the solution described here might help.
Loading ASAM ODS Database values in DIAdem generates “NOVALUE” fields. - NI
it avoids generating the ASAM ODS valuematrix which might the reason why you get the error.
Alternatively you can try to activate submatrices in your naviagtor tree.
now you can load submatrices seperately which also supresses the generation of ASAM ODS Valuematrix.
(605 Views)
