DIAdem
Calculating Channels and variables in SCRIPT
I am new to Scripting in DIAdem 2014.
I am trying to divide the channel "s_delta_L_R" by a value stored in my variable "track".
But when running the script, I always get the error message "Variable 'track' not defined".
This is my code:
dim track
track = 2 'in m
Call Calculate("Ch(""[1]/angle_L_R"")=Ch(""[1]/s_delta_L_R"")",NULL,NULL,"")
Call Calculate( "track=2000" )
Ch("[1]/angle_L_R")=ArcSin( Ch("[1]/s_delta_L_R") / track )
Thanks for your help!
Jonas
(2,873 Views)
Dim track
track = 2 'in m
Call Calculate("Ch(""[1]/angle_L_R"")=asin(ch(""[1]/s_delta_L_R"")) / " & (track*1000) & "",NULL,NULL,"")
But line 3 seems redundant
(2,853 Views)
Thanks a lot! That works great.
It took me a while though to figure out that DIAdem Script doesn't allow to use floating point variables in the "Calculate" function.
The error message always said "Expected end of command" which didn't exactly help 😉
But now that I make sure all variables are rounded to integers before computing, it works perfectly.
Seems like VBS and me are becoming friends after all.
(2,833 Views)
