DIAdem
Calculator not working in DIAdem 18
Calculator option in VIEW and ANALYSIS tab is not working
(1,365 Views)
That is a strange one:
When I work on multiple screens with my laptop and use one of the extra screens to work with the calculator, the calculator will always appear in the last spot it was closed!  So if you are disconnected from external displays, it will still appear "outside" of your screen LOL
What to do:
As soon as you click on the calculator click 'Alt+ Space' you will see small window, as soon as you click 'move', hit the left or right (depends if your extra screens are to the right of your laptop, hit the left key) arrow key and hold until the calculator drags back to view
You can also read through this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015BKuSAM&l=en-US
(1,338 Views)
Hi Veerappen_123,
If the information from gsklyr does not solve the problem, what exactly do you mean with "does not work"?
When you move the mouse over the icon (without clicking), is it highlighted?
What you can also try is to rename the DIAdem desktop folder. For this close DIAdem, go to
c:\Users\<USER NAME>\AppData\Local\National Instruments\DIAdem\2018\
and rename 2018 (for example to “2018Temp”) and restart DIAdem.
Greetings
Walter
(1,295 Views)
