DIAdem
Excel.Application
Hey All
Using Diadem 2017 64 bit and my team has recently updated our version of excel to 64 bit which is causing some problems
I have excel 2010 installed on my machine and when I create an activeX object of excel it defaults to the version 16 which is a 64 bit version
I would like Diadem to open the 2010 version of excel
The following code should open the 2010 version of excel;
Dim excel
Set excel = CreateObject("Excel.Application.14)
however when I return the version number I get 16.0
Call msgbox(excel.version)
Anyway I can force Diadem to open 2010 version of excel?
Tim
(1,556 Views)
I am curious of anyone else can try this and see if the same behavior is exhibited
Tim
(1,465 Views)
Anyone? Try it!  its fun!
Tim
(1,397 Views)
Hello Tim,
I don't have an old Excel version, and so I can't reproduce this behavior, unfortunately. But anyway, "CreateObject" is a VBS (Microsoft) command. And so I can't help in this case. However, you could discuss the magic behind the version change with Microsoft.
Greetings
Walter
(1,379 Views)
