DIAdem
Calling a .SUD within a .Sud
I'm having a problem Calling a .SUD  file within a .SUS file. I have done this in the past and it worked but I'm have a problem with this working now.
What I have done is Created the "Master"  interface with buttons that will call other .SUD programs.
I am working with DIAdem 2012 and am on a network drive.
The Command I am using is :
DataReadPath="\\eares01.vib.com\vol2_07_data_sata$\data1-1\Shared\DIAdem files\program_Thermal\Thermal Cycle
Call SUDDlgShow("Dialog1","Myprogram_name_Plotting_Analog.SUD")
Any Ideas why this will not work now?
Thank you in advanced for your help
Spidey
(5,653 Views)
Hi Spidey,
you should try to set the "ScriptReadPath"-Variable instead or better use the full filename in the SUDDlgShow-function.
Dim sSUDPath : sSUDPath ="\\eares01.vib.com\vol2_07_data_sata$\data1-1\Shared\DIAdem files\program_Thermal\Thermal Cycle\"
Call SUDDlgShow("Dialog1", sSUDPath & "Myprogram_name_Plotting_Analog.SUD")
(5,629 Views)
Accepted by topic author Spidermansrevenge
Thanks Martin
I tried this suggestion but I'm still having an issue.
I have a strong feeling that is Network related..
I need to work this issue with my IT Dept.
Thanks again for your help.
This forum is so helpful and I always get such a quick response!
Spidey
(5,578 Views)
