DIAdem
Can I reference to a group and channel index
I would like to know if I can make calculations, repeating by a loop for different groups, by referring to a Groupindex and a Channelindex.
Here is an example of what I'm trying to do:
if Chnname("[...]/[2]") = Speed 1  Then
RV1(1)=CHD(Find('''Speed 1'<60"), "Distance 1"
Else
RV1(1) =0
End if
this I want to repeat for different Groups so I've put this in a loop. The channelindex stays the same. I tried to fill in a variable for the groupindex however this returns an error: an invalid text operand is used within the formula.
Does anybody know how to solve this issue??
Message 1 of 8
(4,606 Views)
Hello Robert!
My solution is:
Option Explicit
Dim i
Dim n1
Dim n2
' loop over all groups
For i=1 To GroupCount
  ' get the channel 'Speed 1' in the current group
  n1 = CNo("[" & i & "]/Speed 1")
  ' get the channel 'Distance 1' in the current group
  n2 = CNo("[" & i & "]/Distance 1")
  If (n1 > 0) and (n2 > 0) then
    ' find value
    RV1(1) = CHD(Find("Ch(" & n1 & " ) < 60"), n2)
  Else
    RV1(1) = 0
  End If
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Message 2 of 8
(4,595 Views)
Hello Robert!
Additional Info: You should check if the Find is successfull!
Matthias
Matthias Alleweldt
Twigeater?
Message 3 of 8
(4,590 Views)
hello matthias,
This gives an error in the script. It's expecting a statement
Message 4 of 8
(4,584 Views)
Hello Robert!
I copied the script from the post to verfiy your problem. It run without a problem.
Can you please post the excact error message out of the DIAdem report file.
Matthias
Matthias Alleweldt
Twigeater?
Message 5 of 8
(4,581 Views)
Hello again Matthias,
The Exact error is:
Error in <Noname(1).VBS>(Line:32,Column: 7):
Expected Statement
the coordinates reference is at the beginning of
Option Explicit
Message 6 of 8
(4,580 Views)
Hello Robert!
Did you inserted my code into a existing script?
The statement 'Option Explicit' may only appear once in a script before the first statement. Just delete it if it is already in your script.
Matthias
Matthias Alleweldt
Twigeater?
Message 7 of 8
(4,572 Views)
OKe thank you very much for this information.
Regards Robert
Message 8 of 8
(4,563 Views)
