DIAdem
Can't install Diadem 10 on my new computer
To whom it concern
I have received a new computer and wanted to install my Diadem 10.0 software on it. At the same time I received Labview from our central system at Volvo but missed the license. I then installed Diadem 10.0 and it worked. Then my problems started. I needed the CANDriver for cancases from vector but couldn't find any for my version. At the same time my Diadem installation interfered with the Labview license server I then tried to uninstall diadem and Labview but I wasn't successful so I deleted the files with Explorer. After this it was not anymore possible to reinstall neither Diadem or Labview on the computer. The Diadem installation displays: no software to remove or install and the installation is stopped. Is there some missed files, blocking the installation due to the explorer deletion of the NI directory?
Any suggestions
Best regards
Anders
(4,060 Views)
Accepted by topic author aeohagman
Hello aeohagman,
You might want to try the MSIBlast application from Microsoft, but I can't guarantee it will not do any harm to your operating system.
There is a link here:
http://forums.ni.com/t5/LabVIEW/send-me-link-to-download-of-msiblast-to-unistall-labview-8-6/td-p/79...
Generally, Windows applications do not respond kindly when the directories are simply removed - that is not an NI specific issue, but a general Windows situation.
I hope this helps,
     Otmar
Otmar D. Foehner
(4,054 Views)
@Otmar wrote:
Hello aeohagman,
I hope this helps,
     Otmar
Hej Otmar
Thanks for your help.
I have now successfully installed Diadem again
Best regards
Anders
(4,038 Views)
