DIAdem
Can you use a variable for a SUD Title?
Howdy,
I'm just getting started writing some scripts in Diadem, and I was curious, is it possible to use an auxillary variable as a SUD title? For example, for a high level analysis script that will loop through a series of Groups in the data portal, is it possible to send the Group Name to the SUD to use as the title of the box?
Thanks-
Tim
(1,763 Views)
Follow-up question - is there any way to have a Channel Combo Box in a SUD only show the channels from the currently active/default Group? With 10 Groups in the Data Portal it's a bit much to sort through the them to choose the appropriate channel.
Thanks!
(1,732 Views)
Accepted by topic author thawkins87
Hi thawkins87,
Please have a look at this KB for exchanging data between DIAdem and SUD.
The attached example shows how to fill a combo box with the channel names of the default group.
Greetings
Walter
(1,563 Views)
