DIAdem
DIAView.dll could not be loaded / Failed to load dll: DIAView.dll : 2020 SP1 / 2019 SP1
Since many tiles I got an issue with DIAdem. It crashes when I go on "View" Tab:
Nothing is loaded, I just start DIAdem and I click on "View" tab (I still got example data in Data Portal).
If I try to open DIAdem Settings I got a similar issue:
but DIAdem doesn't crash and close. Setting windows opens but right column is empty:
I got this issue in 2019 SP1 version and I try to solve it by installing 2020 SP1 version, without success.
I don't remember doing anything related to DIAdem in this computer. I closed some NI startup services (DataFinder, NI Device Monitor etc.) but even if I relaunch them I still have this crashing issue.
This error is not really verbose so I don't know want to do or where to start from. Someone could help please?
Thanks for your help.
PS : My computer runs Windows 10 Pro 64.
EDIT : sorry for French version ... 😅
(2,355 Views)
Accepted by topic author lsanchez
I found this article :
Error: 'Failed to load dll:DIAView.dll' After Installing DIAdem
Could you test this solution ?
Have a good day
Eloise
NI France
(2,312 Views)
That's it !!! You save my day (and way more).
I already had the "Visual C++ Redistributable for Visual Studio 2015" (x68 only) installed but the "c:\Windows\System32\vcomp140.dll " was missing. 😮
I just had to made "repair" on my add/remove software to have it back. And now I can go on the DIAdem's "View" tab. 😎
Thanks a lot for your help !
Enjoy !
(2,304 Views)
