DIAdem
Change cursor line thickness and line thickness of plotted channel in the DIAdem VIEW
Is it possible to change the line thickness of the cursor and the plotted channels in a 2d graph in the DIAdem VIEW?
A selectable cursor thickness or even the possibilty to change the cursor to another symbol would be really nice.
If I use the play function in the DIAdem VIEW is hard to see the cursor in the not selected graphs in case of multiple 2d graphs.
With kind regards,
Stijn
(7,092 Views)
Right click on the graph>>Display>>Click on properties of the graph you wish to configure>>Line Width. Note: I found that I need to change Marker Style fist. I used 2010. Not sure whether later version need to do so.
(7,075 Views)
Is it also possible to change the cursor style/line thickness?
(7,056 Views)
Hi Stijn,
I am not aware of any way in DIAdem 2012 or earlier to set the line style or size of a curve or a cursor in DIAdem VIEW.  Everything can be configured in REPORT, but only markers and line color in DIAdem VIEW, which is built primarily for display speed, not display flexibility.
Brad Turpin
DIAdem Product Support Engineer
(7,049 Views)
