DIAdem
Change mouse cursor appearence in script
Is it possible to change the appearance of the mouse cursor in a script?
A couple of the scripts I've created takes a little time to execute, so I'd like to change the cursor to the hourglass while waiting for the script to finish (and then change it back to normal at the end of the script).
Are the other ways of letting the user know that a little patience is required?
(4,066 Views)
Hi Salte,
The following commands show a progress display in the status bar:
Call AutoLoopInit()
Call Pause(10) 'Replace this line by your time-consuming task
Call LoopDeInit()
Call Pause(5) 'Just to see what happens when the script stops
In the user dialog boxes you could use the method BeginWaitCursor to display the mouse cursor as an hourglass.
Hope this helps,
Ralf
(4,055 Views)
Hi salte,
I like to use the following code, while waiting for a scipt:
call MsgBoxDisp("Please wait...","MB_NoButton","MsgTypeNote",,,"YES")
' your code that takes the time
call MsgBoxCancel
greets Andreas
Volkswagen AG
Wolfsburg - Germany
(4,038 Views)
Thanks for your suggestions.
I'll probably use one or both of them in some way.
(4,032 Views)
