Hi BBchico,
I'm going to answer the question I think you're asking. If I guessed wrong, please fill me in more specifically. Look at the files in the ZIP attached below to see the configuration dialogs you need to go through to rotate the table headers. You also probably want to increase the percentage of the table that the header area takes up. There is also a TDR layout that you can try directly in your DIAdem, assuming you have DIAdem 9.0 or later.
Brad Turpin
