DIAdem
Change orientation for table label labwindows ?
I have a table whith strings for label. I want change the oriantation of the columns labels. How can i do that ?
(3,234 Views)
Hi BBchico,
I'm going to answer the question I think you're asking. If I guessed wrong, please fill me in more specifically. Look at the files in the ZIP attached below to see the configuration dialogs you need to go through to rotate the table headers. You also probably want to increase the percentage of the table that the header area takes up. There is also a TDR layout that you can try directly in your DIAdem, assuming you have DIAdem 9.0 or later.
Brad Turpin
DIAdem Product Support Engineer
(3,234 Views)
