DIAdem
Changing Base of Log Scale - Possible?
If we select Log for an axis - it is Base 10 - is there a way yet in DIAdem to change the base of the Log function to Log base 2 for example?
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(2,953 Views)
Accepted by topic author RVallieu
There is not a direct option for changing the base of the logarithm in the scale in the .
The simplest workaround here is to create a new data channel for whichever axis you want to be logarithmically scaled and actually modify the data (x-series or y-series) in that channel by performing the log function you need. Granted, the grid system will not update accordingly.
(2,920 Views)
Thanks for the insight.
(2,916 Views)
