DIAdem
Is there a portal selection change event?
Is there a way I can detect when a user selects something different in the data portal?
Thanks!
(2,944 Views)
Do you mean an event that occurs anytime someone clicks on a different channel/group in the Data Portal pane?  Or an event that occurs whenever data from the Data Portal is used somewhere?  (e.g. VIEW, ANALYSIS, etc.)
Highest Regards,
Paul
(2,909 Views)
"an event that occurs anytime someone clicks on a different channel/group in the Data Portal pane" - yes!
(2,898 Views)
No there isn't an event for data portal.
(2,895 Views)
Just for clarity, there is no such Portal change event as of DIAdem 2017.
(2,887 Views)
