DIAdem
Each TDMS Channel as Different DUT
I have data in a TDMS file where each channel is a separate DUT. I want to plot a chart with the X-axis as the DUT number, and the Y-channel as the data within that DUT-channel. Can this be done in DIAdem? Maybe I've missed something but so far I haven't found how to do it.
(2,671 Views)
Hi apatelsigma
If I've understood correctly there's an example in DIAdem called 'Pareto Diagram'. If you get a list of labels (DUT Numbers) within a channel (X) and pull the relevant data into another channel (Y), you can plot them against eachother.
Chris
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
(2,637 Views)
Hi apatelsigma,
What do you want that plot to look like... a single 2D curve, multiple 2D curves, a 3D surface, a 3D waterfall, etc.?  It would really help if you would submit a typical data set to see what options you have.
Brad Turpin
DIAdem Product Support Engineer
(2,615 Views)
