DIAdem
Changing a report object's name
I'm using this command in my script
oMyObjects.Item("Text1").Text = Data.Root.ChannelGroups("PhotoSet" & i).Properties("Caption").Value
This is great, it works fine.
However I'm not happy with the object having the name of Text1, I would like it to be PartNumber.
How do I change this?  I just can't find it on the Report tab...
Denis
(5,665 Views)
Accepted by DJ_001
Denis,
the easiest way to do this is selecting the object in REPORT and then select "rename" from the context menu
(5,661 Views)
Well, now I feel like a dolt...
thanks for pointing it out for me
Denis
(5,658 Views)
Hi Denis,
Don't feel like a dolt, that context menu was first introduced in DIAdem 2010.  Prior versions of DIAdem required you to edit the TDR file in a text editor (ugly).
Brad Turpin
(5,601 Views)
