DIAdem
Channel Data filters in DIAdem
Hi All,
I am having NI DIAdem installed in my system.
I am having data to be analysed in .csv format and the same data i am able to see in DIAdem.
There are number of channels in this data.
There are Channel filters in DIAdem at the top right corner on Data Portal which can filter one channel within the entire channels in the data.
Suppose in one channel, i am having date & time (time stamp) when a particular data record was recorded having different channels in it..
Now, this channel is having say 1000 records/data corresponding time stamps.
My question is can i filter entire data as per the selection of time stamp for one channel/channels(s).
I did not found any tool in DIAdem to do this.
Can anyone tell me.
Samriddh Sarbalhi
(5,197 Views)
Hi Samriddh,
Let me try to clarify your request.  Let's stay with the example of data channels with 1000 values in them.  Will each channel have one date/time value associated with it or 1000?  Will all the channels in one data file have the same date/time value?  Do you want to concatenate together all the channels which have date/time values in the correct range?  If so, will some of those channels to concatenate come from different files?
I think we can use the DataFinder to tackle these issues, as long as you don't have 1000 different date/time values in each channel.  In that case we'll need to use a channel calculator or calculation manager session to filter the specific rows you want from one or more channels.
Brad Turpin
DIAde Product Support Engineer
(5,194 Views)
