DIAdem
Script to change the linestyle in a report graph
Hi all,
Is there a way to automate the formating of (linestyle) of a graph plot in a report?
grtz,
Ben
(4,153 Views)
Accepted by topic author Ben_Engelen
This code will access the line style in an axis system:
Call GraphObjOpen("2D-Axis1")
  Call GraphObjOpen("2D-Axis1_Curve1")
    D2CurveLineType  = "solid"
  Call GraphObjClose("2D-Axis1_Curve1")
Call GraphObjClose("2D-Axis1")
Please note that you need to know the name of the Axis system and the Curve you wish to change and use the correct names in the GraphObj... commands.
The best way to find these commands is through the Ctrl-A function in DIAdem.
Valid entries for D2CurveLineType are:
Script Term Interface Term, Explanation
solid
Line
dash&dott.
Dots and dashes
dashed 1
Dashes 1
dashed 2
Dashes 2
dotted
Dotted
I hope this helps,
     Otmar
Otmar D. Foehner
(4,145 Views)
