02-02-2007 10:14 AM
02-02-2007 10:19 AM
Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
02-02-2007 10:21 AM
02-02-2007 10:47 AM
02-05-2007 11:12 AM
Hi bm2cox,
Why don't you use the 'ChnClpCopy()' suggestion of Matthias' and simply prepare a new set of channels to export? It's a workaround, but it should give you what you want. If you have DIAdem 9.0 or later, I'd recommend creating a new Group to make deletion of the temporary channels easier. Then copy the selected area of data from the original channels into a set of new channels. Then use the 'ChnClpCopy()' command to send all the values plus the channel names from the newly created subset channels to Excel. Finally you'll want to delete those temporary subset channels.
Brad Turpin
DIAdem Product Support Engineer
