DIAdem
Channel number of samples
how can i change the number of sample of a channel ?
For example i have 1000 samples, but i have to reduce samples number to 300 .
Message Edited by simone_o on 07-01-2008 11:21 AM
(4,252 Views)
Hello Simone!
Assuming you want to reduce the samplerate have a look at the ChnMapLinCalc command.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,247 Views)
Hi Simone_o
Hopefully the following document can be useful for your purposes: KnowledgeBase 3LDM8O9F
Best regards.
Hudson | NIIT AE
(4,229 Views)
Hi simone_o,
You could also choose to reduce-load the data set, so that the 1000 data points are loaded as 300 data points.  Instead of dragging the data file from the NAVIGATOR into the Data Portal, right-click on the data file and select the "Data Reduction..." menu.
Brad Turpin
DIAdem Product Support Engineer
(4,216 Views)
