DIAdem
Scaling of Datavalues in Data Plugin
Hi There,
I am trying to bring up a data plugin where the channels values needs an offset and an factor. The Factor information is obtained through a single value in the file, but the offset is the previous value of the channel.
For Example,
if 1,2,3,4 are the channel values and Factor is 0.1
Then the 1st chnnael value is 1*0.1   = 0.1
2nd Channel Value is = 2 * 0.1 + 0.1 = 0.3
3rd cahnnel value = 3 * 0.1 + 0.3       = 0.6
4th Channel value = 4 * 0.1 + 0.6      = 1
I am not quite sure How I can get this information on the offset. Can you please help me out with this.
Waiting for you earliest response.
Priya
Message Edited by pria on 06-30-2008 12:50 PM
(3,585 Views)
Hi pria,
There is no way to do this with DirectAccessChannels, you will need to parse each data value manually in VBScript in the DataPlugin code, then use the Channel.Values(i-1) property to return the previous value to use for Channel.Values(i).
Brad Turpin
DIAdem Product Support Engineer
(3,564 Views)
Hi Brad,
Thanks for letting me know this. I should be be to get all my future plugins correctly.
Priya
(3,545 Views)
