DIAdem
Channel values read
Hi everyone,
I have a very trivial problem.In a SUD dialog I load and display some channels in a  channel-combo-box.So everythings perfect so far,but I have some texts channels and I have text entries which lenght may vary, but I cannot figure it out how to display the text channel values in a combo-box, after the corresponding text channel is selected.It can be very simple if there is a command which is sthg like 'read channel values'. I had an idea , which is more time consuming, I can create a dinamic array and use a enumeration-combo-box but I'm in kind of a hurry.So if you have an idea about it I'll be most grateful.
Thanks in advance
(5,774 Views)
Hello!
AFAIK is there no build in function in DIAdem. You have to do it yourself.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(5,772 Views)
Thanks Matthias,
at least I know now 😞
Have a nice day
(5,770 Views)
Accepted by topic author fscommand
Hi fscommand,
I dont know if it might be helpful for you but if you want to write or read text channel values there is a command called CHT.
For example:    reading  MyText = CHT(3,"Group1/TextChannel")
                        writing   For intLoop = 1 to 10 CHT(intLoop,MyChnName(0)) = "Value " & intLoop Next    //for loop writing values
Greg
(5,714 Views)
Wow  G.INNI,
you are my hero/ine 🙂 It actually works pretty well with CHT ,thanks again!I'll kudo you for that.
Have a nice weekend
(5,711 Views)
hello,
I was wondering if you could help me write a data plugin for XML! since you have already worked on one!
cheers!
(5,453 Views)
