DIAdem
radiobutton
Hy to all,
I have a short question regarding the RadioButton.
How can I call a radiobutton from another dlg.
I have in a SUD file, 2 Dlg and  2 radiobutton commands, 1 radiobutton on a Dlg and another radiobutton on another Dlg, and I want to use inside to a normal button an IF command, command that depends on the state of an radiobutton from other Dlg.
For example:
 If Radiobutton1.Value = 2  And Radiobutton2.Value= 1 Then
 Call ---------------------------
 End If
It is possible?
Thank you for your time,
Marius
(3,586 Views)
Accepted by topic author Marse
Hi Marse,
You're going to need to assign a global variable to that radio button control, then you'll be able to access the global variable from the other dialog.  I checked with R&D, and they said that's the only way.
Brad Turpin
DIAdem Product Support Engineer
(3,560 Views)
