DIAdem
Check if a channel object variable exists
How do I check if a channel object variable was successfully set?
Early in my code I use the following to determine if a channel exists and, if so, to set a channel object variable to represent it:
If Data.Root.ChannelGroups(1).Channels.Exists("Yaw Rate Gain") Then
  Set YRateG = Data.GetChannel("Yaw Rate Gain")
End If
Later in my code I'd like to check if YRateG is valid but I can't find a way of checking without tripping an error if it isn't.
I've tried using IsNull on YRateG.Name and I've tried Data.Root.ChannelGroups(1).Channels.Exists(YRateG.Name), but neither worked.
Thanks, Simon.
(1,977 Views)
Accepted by topic author Simon_Aldworth
Hi Simon,
I'd recommend you use the IsObject(YRateG) comparison.  As long as you don't initialize the variable to Nothing or re-use it between the Set assignment and when you compare, this should work.
Brad Turpin
Principal Technical Support Engineer
(1,937 Views)
dim YRateG : Set YRateG = nothing
End If
if not YRateG is nothing then
end if
could be an alternative.
Be aware that isobject will also return true for nothing.
(1,919 Views)
