DIAdem
How do you Populate ListBox with Channel Group Name Dynamically?
I've built a GUI in the "View" pane that acts as a large table of contents. At the top of the GUI there is a list box that I would like to populate dynamically with the channel group names loaded in my data portal (internal data). I cannot seem to generate the code necessary to do this. Currently, I am using a ListBox. Should I be using an EnumListBox instead?
The purpose of the listbox is to allow for quick loading of the data that is to be analyzed into multiple sheets (also in the "View" pane) for side by side comparison rather than having to drag and drop data into each individual sheet.
Any help would be much appreciated,
~Nathan
Attached is a screenshot of the GUI hopefully it helps.
Message 1 of 11
(6,740 Views)
Currently my code looks like this:
Dim listNum, Names
for listNum = 1 to GroupCount
 Set Names = GroupName(listNum)
 selectData.Items.Add(Names)
next
The error I keep receiving occurs where I try to "Set Names = GroupName(ListNum)" and is an "Object Required: '[string: "filename"]'
where filename refers to my particular channel group name.
Message 2 of 11
(6,739 Views)
Accepted by topic author Nate102
Hey Nathan -
Have we met yet?  Don't think I recall seeing you post on the DIAdem forums thus far (nor do I remember meeting someone named Nathan in person recently).  Welcome to the DIAdem forums!
There's a few things you need to alter about your code snippet -
  1. The reason you're getting the error "Object Required: '[string: "filename"]' is because the Set command expects that the right side of an expression returns an Object (that you set your variable to).  In your case, you're returning a string (the name of a Group), not an object.  Simply remove the Set command.
  2. The ListBox.Items.Add() method requires two parameters - the first is the text of the item to insert in the list, and the second is a value to assign to that item (which you should make unique).
Therefore, to most directly map your code snippet to working code, use the following:
Dim listNum, Names
FOR listNum = 1 TO GroupCount
  Call selectData.Items.Add(Names, listNum)
NEXT
Note that you can also use object oriented programming with the Data object representing the Data Portal, if it's easier for you to avoid remembering DIAdem variables such as GroupCount and GroupName (it is for me):
Dim listNum
FOR listNum = 1 TO Data.Root.ChannelGroups.Count
  Call selectData.Items.Add(Data.Root.ChannelGroups(listNum).Name, listNum)
NEXT
Your project is looking great - let us know how we can continue to help and keep us updated!
Derrick S.
Product Manager
NI DIAdem
Message 3 of 11
(6,721 Views)
Hi Derrick,
We just recently acquired DIAdem at work. We're making the transition from Excel data processing and analysis to something more powerful, ergo DIAdem. Our colleagues in Germany have been using it for quite some time now and we decided to give it a try for uniformity's sake. Thanks for the help regarding this issue. My VB knowledge is very limited. I decided to use the object oriented version and it worked perfectly.
~Nathan
Message 4 of 11
(6,717 Views)
I got a question about the code you write:
Dim listNum, Names
NEXT
What is the "selectData" in this case?
Variable of the listbox?
My purpose is to get all my groups name in a list box
Thanks and happy new year 😉
Fred
Message 5 of 11
(6,301 Views)
Hi Fred,
"SelectData" in that code is the name of the ListBox control in the SUDialog.  It functions in the SUDialog callback code like an object variable, but it's actually a ListBox object.
Brad Turpin
DIAdem Product Support Engineer
Message 6 of 11
(6,285 Views)
Thanks it works now 🙂
I got another problems
I have 2 listbox, one display all the groups names (at eventinitialize), the other should display the channels the selected group from the first listbox.
So at first I display all groups in ListBox1
Sub Select_Groups_EventInitialize(ByRef This) 'Created Event Handler
Dim listNum, Names
  Call Select_Groups.Items.Add(Names, listNum)
NEXT
group_selected = 1
End Sub
 Then I made a oneclickevent on the first listbox which refresh the second box.
Sub Select_Groups_EventMouseDown(ByRef This, Button, Shift, X, Y) 'Created Event Handler
call Select_Channels.Refresh
End Sub
When I refresh the secund box, it find all the channels in a group this way:
I begin at the first group (Index_Group) and I count all channels in it
I Increment the group number and I add all the channel to the previous number (Final_Channel_Number)
and this until I reach the selectioned_group
Then I know the channel number begin in the selectioned_group and the channel end number by adding the number of channels in this group
Sub Select_Channels_EventRefresh(ByRef This) 'Created Event Handler
Dim Index_Group,Final_Channel_Number
Index_Group=1
Final_Channel_Number=0
If(group_selected>1) Then
    Do
        Final_Channel_Number = Final_Channel_Number + GroupChncount(Index_Group)
        Index_Group = Index_Group + 1
    Loop Until(Index_Group >= group_selected)
End If
I display these channels into the listbox2
Dim listNum2, Names2
Call Select_Channels.Items.RemoveAll
FOR listNum2 = Final_Channel_Number+1 TO Final_Channel_Number+GroupChncount(group_selected)
  Names2 = ChnName(listNum2)
  Call Select_Channels.Items.Add(Names2, listNum2)
NEXT
End Sub
My questions are:
Why do I have to click 3 times in the Listbox1 to get my values in the lisbox2?
Is there a easier way of getting the channels begins and end number of a specific group?
Thanks for support 🙂
Fred
Message 7 of 11
(6,274 Views)
Hi Fred,
I am not sure why you were having to click 3 times to update the listbox, but I was not able to replicate this behavior.  I was able to get a Dialog working to properly display the channels in a group by handling the EventChange event from the first listbox.  In this handler, I updated the group_selected variable and called the refresh function of the second listbox.
Sub Select_Groups_EventChange(ByRef This) 'Created Event Handler
group_selected = Select_Groups.Selection
End Sub
I seems to me that EventMouseDown catches all mouse clicks in the Dialog, not just clicks on the listbox.  Using EventChange, we will run the code everytime the selection is changed.
Your method of finding the begining and ends of the groups is perfectly viable as long as you can follow the logic of it.  You could change the code to iterate through the groups and index them individually rather than collectively, but your current implementation seems to be working.
I have attached the Dialog which I created for you to reference.  I tested it in DIAdem 2012.  Hope this helps.
Justin D
http://www.ni.com/support/
Message 8 of 11
(6,234 Views)
The problem disapear with eventchange, thanks 😉
Message 9 of 11
(6,217 Views)
I have tried to use this code in DIAdem 2019 and keep getting the message Object required: "
Dim listNum, Names, selectData
NEXT
Call MsgBoxDisp (selectData)
Anyone got any ideas?
Hannah
Message 10 of 11
(3,483 Views)
