DIAdem
ChnAreaDel deleting wrong rows in a string channel
I am trying to write a script in DIAdem 2010 SP1 to delete the first row of a group that contains two string channels and one time channel, but the
wrong data is being deleted from the string channels.
I start with a file that contains a group like this:
ExampleLog_Before
I run this code expecting the first row to be deleted
Dim logGroup
	Set logGroup = Data.Root.ChannelGroups("Log")
	Call ChnAreaDel(logGroup.Channels("Name"),1,1)
	Call ChnAreaDel(logGroup.Channels("ID"),1,1)
	Call ChnAreaDel(logGroup.Channels("Timestamp"),1,1)
but end up with this:
ExampleLog_After
The first row of the Timestamp channel is deleted, but the Name and ID channels get their last rows deleted.
I have played around a bit and it seems to me that for a string channel ChnAreaDel only deletes from the last row.
Is there another function I should use?
Any help would be appreciated.
Thank You,
Joe
(4,332 Views)
Accepted by topic author JFiddie
Hi Joe,
I've reproduced that ChnAreaDel()  bug you reported in both DIAdem 2010 and 2011-- really odd.  In the meantime, you can use this older approach that uses a string parameter to point to the channel collection to remove the row(s) from:
Set logGroup = Data.Root.ChannelGroups("Noise data results")
ChnStr = ""
FOR Each Channel In logGroup.Channels
  ChnStr = ChnStrAdd(ChnStr, Channel.Properties("Number").Value)
NEXT
Call DataBlDel(ChnStr, 1, 1)
Brad Turpin
DIAdem Product Support Engineer
(4,315 Views)
Thank you Brad,
Your alternative worked like a charm.
I had came across the DataBlDel command in Help, but the last note says that you cannot perform block operations on text channels, so I didn't try it.
-Joe
(4,307 Views)
