DIAdem
ChnAreaDel deleting wrong rows in a string channel
Hi, I have a string channel. If the string channel row value doesn't match the expected string, I want to delete this row. I don't know the row number until the not match string is detected.
iloop is the row number I loop through. For example, iloop can be 1,2,3..
Here is the expression I use,
  Set oMyAssgnList = Data.GetChannels("[1]/"&cstr(CNoXGet(1,3*iloop-1)))
  Call Data.Remove(oMyAssgnList)
Data.GetChannels("[1]/"&cstr(CNoXGet(1,3*iloop-1))) doesn't work.
Is there a way to make this work?
(2,584 Views)
Just noticed this is not the correct post, sorry for the confusion.
(2,550 Views)
