DIAdem
Copying Settings Across PC's/Users
Am currently running Diadem v14 SP1, on Windows 7 64bit.
We have several PCs running Diadem, and a on some of the PCs Diadem that gets used by several different logins.
I continually update various scripts (VB auto sequences) that are stored on the network that are referenced by these copies.
Is there anyway to have all copies of Diadem use the same settings file (ideally stored on the network), so that if I change a setting it gets used by all users. Currently I need to update each PC, and each users setting via their logins, and this is time consuming. Failing that could I perhaps have any autosequence that on startup copies a master settings file for each user on startup?
(2,522 Views)
Hi Onkar,
Below is some information on saving and loading Diadem settings files:
http://zone.ni.com/reference/en-XX/help/370858N-01/dlgshell/dlgshell/ddd_file_save_dialog/
http://zone.ni.com/reference/en-XX/help/370858N-01/dlgshell/dlgshell/ddd_file_load_dialog/
It looks like you can create a file, save this to a server and then load this file to load settings.
Jack
(2,488 Views)
