DIAdem
ChnClassXRedXY()函数使用
最近使用DIAdem处理数据时候用到ChnClassXRedXY()函数,具体目的是将一组数据进行分段截取,函数调用语句如下:
Call ChnClassXRedXY("Time","Time","Spindle Power","NoBeginEnd", "Mean")
这组数据包含时间"Time"和另外一组信号"Spindle Power",想按照时间,提取每一小段时间中信号"Spindle Power"的平均值,也就是进行均值滤波,但是设置的时候全局变量都设置好了,应该没有问题,事先通过Analysis中的Statistic进行了计算得出了希望的结果,但是编程后得到的结论出现错误,不知道应该注意哪些地方?猜测可能是参数("Time","Time","Spindle Power","NoBeginEnd", "Mean")的设置问题?调整了很长时间,都出错,希望能得到NI或相关专家的帮助
谢谢
(4,356 Views)
Hello AwenTang,
Unfortunately I cannot read Chinese. Could you please repeat your question in English.
Do you want to run a one- or two-parametrical reducing classification?
Christian
(4,343 Views)
Hello, Christian
Very luckily, I have solved this problem this evening. It's the wrong parameters I set. Thank you all the same.
 Awen
(4,335 Views)
