DIAdem
DIAdem 9.1 access violations
We are getting about 4 to 5 times a day on this "ACCESS VIOLATION" errors while developing a Crash Analysis software.
Here are the error logs that we have collected, hope you guys could toss us few possible solutions to this.
Note that error # 23 was due to freezed data protol after crash.
21   **** Error registered on 3/9/2008 at 1:31:05 PM [Message file:GLOBERR / Text area:1 / Text number:409]
     Runtime Error while executing command "CHNVCCALC(1,"TempChest","DrivChestVC",229,1.3,"ECE_94")"
     Error type: ACCESS VIOLATION
     Error address: 00000000
     Module name:Ní
22   **** Error registered on 3/9/2008 at 1:31:06 PM [Message file:GfSSud / Text area:3 / Text number:1]
     The following error occurred
     when executing the dialog box Dlg19
     from the Settings.sud file:
     < Object: 'Button1', Event: 'EventClick', Line: 54 >
     Module name:Ní
23   **** Error registered on 3/9/2008 at 1:31:08 PM [Message file:GLOBERR / Text area:1 / Text number:587]
     An invalid text operand   is used within the index operation of the formula
     CHNVALMAX(0):
24   **** Error registered on 3/9/2008 at 1:31:08 PM [Message file:GfSSud / Text area:3 / Text number:1]
     < Object: 'Button27', Event: 'EventClick', Line: 355 >
     Module name:Ní
25   **** Error registered on 3/9/2008 at 1:31:09 PM [Message file:GfSSud / Text area:3 / Text number:1]
     when executing the dialog box Menu
     < Object: 'Button2', Event: 'EventClick', Line: 19 >
     Module name:Ní
**** DIAdem-ENDED on 3/9/2008 at 1:31:35 PM ************************************
**** DIAdem-STARTED Version: 9.1 on 3/9/2008 at 1:31:47 PM *********************
and
37   **** Error registered on 3/9/2008 at 2:04:56 PM [Message file:GLOBERR / Text area:1 / Text number:409]
     Error address: 00084218
     Module name:OTP801ASU.dll
38   **** Error registered on 3/9/2008 at 2:04:56 PM [Message file:GfSSud / Text area:3 / Text number:1]
     < Object: 'Button1', Event: 'EventClick', Line: 62 >
and
14   **** Error registered on 3/9/2008 at 11:46:31 AM [Message file:GLOBERR / Text area:1 / Text number:409]
     Runtime Error while executing command "CHNMOVE(121,5,201)"
     Error address: 0008426D
15   **** Error registered on 3/9/2008 at 11:46:32 AM [Message file:GfSSud / Text area:3 / Text number:1]
     when executing the dialog box OutputStatus
     <(Declarations), Line 142>
16   **** Error registered on 3/9/2008 at 11:46:32 AM [Message file:GfSSud / Text area:3 / Text number:1]
     < Object: 'Button7', Event: 'EventClick', Line: 4 >
**** DIAdem-ENDED on 3/9/2008 at 11:48:01 AM ***********************************
(3,912 Views)
we have had no issues or changes in this function since DIAdem 6.5.
For further investigation we need an appropiate data set. You can post the data set in this forum or mail the files direcly to stefan dot zoelsch at ni dot com.
StefanZ
(3,897 Views)
I've checked the error database but I've found nothing in relation with ChnVCCalc.
Could you provide me the data set you used to run the Crash function?
Could you also send me the desktop.ddd located in the DIAdem program folder?
Christian
(3,896 Views)
