DIAdem
Column-Limitation of Import-Wizard
im using the 2018 Version of DIAdem and have a problem with the Import-Wizard for creating a DataPlugin. The .csv im using has about 600 columns with different datatypes. Unfortunately the Import-Wizard let me configure only the first 200. Is there any simple Solution?
Thank you.
(1,077 Views)
Hi DGparagon,
I'm afraid you've bumped up against one of the limitations of the DataPlugin wizards.  I recommend that you change gears and try scripting a DataPlugin from scratch using the VBScript api described in the DIAdem Help.
If you'd like help with that process, just post here or email to me (brad.turpin@ni.com) several raw data files. I can take a stab at creating such a DataPlugin from scratch and return the resulting *.uri file to you.
Brad Turpin
Principal Technical Support Engineer
NI
(1,053 Views)
