DIAdem
Comma delimated to semicolon delimated
I have an xlsx file which i am saving it to a .csv file. The .csv file is a comma delimated file and I nned it to be semi colon delimated(;) one. Can it it be possible via vb script.
I am using
Call myWorksheet.SaveAs(newpath2&"\"&"CSVFileName_" &Data.Root.Properties("DATE").Value  &  ".csv",6)
(2,921 Views)
In DIAdem you can call a script like this to save a comma seperated file or use the file dialog and save to "CSV_EXPORT" and export accordingly.
Option Explicit
dim filePath : filePath = "C:\temp\CSVFileName_" & replace(Data.Root.Properties("datetime").Value, ":", "_") &  ".csv"
' configure export
dim expParams : Set expParams = Navigator.Settings.CreateDataPluginParameter("CSV_EXPORT")
expParams.Delimiter = eCSVExportDelimiterComma
expParams.DecimalSign = eCSVExportDecimalSignPoint
' write file
call DataFileSave(filePath, expParams)
or just export to Excel by saving or calling
Option Explicit
dim filePath : filePath = "C:\temp\CSVFileName_" & replace(Data.Root.Properties("datetime").Value, ":", "_") &  ".xlsx"
call DataFileSave(filePath, "ExcelTdmExport")
(2,896 Views)
I reframe the question.
I am writing some data,after calculations, from tdms file to .xlsx file.  I am then saving this file as .csv.
At the moment I am able to save the .csv as Comma(,) Delimated but I need it to be a semi/colon delimated(;).
I don't want to save the tdms into .csv.
And it Needs to be done via script.
(2,889 Views)
Option Explicit
' configure export
expParams.Delimiter = eCSVExportDelimiterSemicolon
' write file
Be aware that some semicolon deperated files also need the decimal settings to be changed.
(2,885 Views)
