DIAdem
Data format (.R64) on MatLab
We are executing some vehicle function tests and collecting those data via Datalogger Ipetronik M-log. Currently we are able to plot graphs no DIADem, however the data that we are generating is on a really raw format to open it on MatLab (.I8 ; .I16 ; .W8 ; .W16 ; .W32).
Could you please inform me if is it possible to convert those files into a suitable file (e.g. .R64) to open it on MatLab?
Thanks in advance for your support.
(3,244 Views)
Hey jmbraga,
I'm not into the details of your application, but I believe the best scenario could be you sending the data directly from your Datalogger to MATLAB. for that part, it would be a good try posting on MathWorks forum.
Now, if your application requires you to transfer data form DIAdem to MatLab, I found some interesting links that might help you.
Methods for Working with DIAdem and MATLAB®: Data Transfer and Interprogram Communication - This link shows that you can use scripts to communicate both applications
MATLAB® DataPlugin - This DataPlugin supports the reading/importing and writing/exporting of data files created by The MathWorks, Inc. MATLAB® Software.
Import DIAdem *.dat (R64) into Matlab - This post from MathWorks contains a script used to transfer R64 data that you mentioned on your post.
I hope I could help with that!
Have a great Week!!
Felipe Flores
Technical Support Engineer
(3,189 Views)
