DIAdem
Command for closing groups in the data portal
can I use a command in a script to close all groups in the data portal (same like Pressing "/" on the num pad).
Gabriel
(4,641 Views)
Accepted by fischerg
Hello Gabriel,
you can use
Portal.Structure.Collapse(Data.Root)
DIAdem supports the API's PORTAL and DATA since version 11.
Greetings
Walter
(4,640 Views)
I put the code
    Call ChnRenumber()
in a script and stored it in a file (script.vbs).
Then I assigned the script to one of the script-buttons (to use with shift an F1-F12).
If I press Shift+F12 (my assigned Shortcut), I realize that the script is executed, but nothing happens in the Dataportal. I press the correspondent button it works?
Why??
Gabriel
(4,595 Views)
Hello Gabriel,
You are right. That seems to be a wrong behavior. But here is a work-around:
Pause 0.01
Greetings
Walter
(4,593 Views)
Hello Walter,
Thanks, it works.
(4,590 Views)
