DIAdem
Command to transfer a View Layout to Report
Hello.
I have always used the Button to transfer a VIEW layout to the REPORT window, but I have already noticed that this only functions when the report preferences are set in "Number referenced". What I want to do is to change programatically this option to Number referenced and then transfer the layout. The question is, how to do the transfer?
Does anyone have an idea?
Regards.
(3,443 Views)
Hi ingluiseflorest,
I've tested that behavior with all variations of "Name oriented" and "Number-oriented" settings in VIEW And REPORT. As I could see it worked fine in DIAdem 10.2 as well as in DIAdem 11.0. What is the DIAdem version you are working with?
Greetings
Walter
(3,410 Views)
