DIAdem
Display of registerint, registerval and registertxt values of Channel in V11
I have old data that uses the old built-in properties of registerint#, registerval# and registertxt# values of a Channel in V11.
I was trying to view the properties and I was unable to add these properties within the "select properties" method.  This happens in the data portal and the VIEW table.
I have no problem viewing them 10.2.
How can I display them in V11?
Jim
(3,447 Views)
Jim,
There is a button in the "Settings > Options > General" menu called "Compatability". In the dialog that pops up when you press that button, uncheck the "Hide register properties" box, and all your register variables should be visible again, in all modules of DIAdem.
Hope that helps,
Otmar D. Foehner
(3,444 Views)
