DIAdem
Controlling Diadem from c# application
I am using diadem advanced edition 2102.
My project include c# application that need to controll diadem. i found out that ToCommand object can do the job, and i succeeded with that.
My application needs to control diadem graph player - play/stop/goto..
***The problem is when i click play(the diadem graph player start moving) but if i want to stop diadem after play was Clicked (from the c# application) diadem must to be stopped from himself to get c# application stop command,
that means that after play was clicked i need to stop the diadem himself in order to send him new commands.
thanks
(6,399 Views)
How are you trying to stop DIAdem? what functions are you using for that?
http://forums.ni.com/t5/DIAdem/diadem-and-c/td-p/450631
Applications Engineer
(6,363 Views)
Hi Oz,
The Cursor.Play() method has a boolean parameter that controls whether the command returns synchronously (1) or asynchronously (0).
Call WndShow("VIEW")
Set Cursor = View.ActiveSheet.Cursor
Call Cursor.GotoStart
Call Cursor.Play(0)
MsgBox "Done"
Call Cursor.Stop
Tthis sequence of commands works in a DIAdem VBScript, and it ought to work through the ActiveX layer (though I haven't tested it).
Brad Turpin
National Instrumetns
Brad
(6,328 Views)
Dear OzShimon,
Can you please send me the code you have used in c# to control Diadem? I am new to Diadem and have no clue how to use it in c#. I am also trying to send an excel sheet as input to diadem to create groups and channels.
Thanks in advance.
(6,160 Views)
Hi EagleEye,
I would go ahead and post a new thread.  Since this thread is older it will not get any traffic on it unless people specifically search for the topic.
Peter T
(6,126 Views)
