DIAdem
Convert a channel from Hexidecimal to Decimal
Is there an easy way to convert a channel from HEX to Decimal without having to change every individual measurement.
I am currently using the following command:
 HEXnumCOVNVERTED = (CLng("&h" & HEXnumTOconvert))
Just curious if there was an easier way around this.
BBANACKI
(4,260 Views)
Sure,
and you can use the same command for it. Simply use the DIAdem Calculator, which is capable of doing the calculation for a complete channel - row by row.
The syntax would be something like: ch("dec") = CLng("&h" & ch(1))
In the formula, replace Ch(1) with the channel you would like to convert.
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(4,255 Views)
Hi All,
Note that the Channel Calculator can only execute string parsing in DIAdem 10.1 or higher.  This capability and the new VBScript syntax Ingo suggested will only work in DIAdem 10.1 or higher.
Brad Turpin
DIAdem Product Support Engineer
(4,239 Views)
Thank you.
That is exactly what I needed.....
BBANACKI
(4,234 Views)
