DIAdem
How would you preform an allan deviation on data in DIADEM?
(3,903 Views)
Unfortunately there is no prepared function for the allan deviation. So you will have to do the analysis manually, in individual steps. I am not sure about how the deviation is actually calculated but a function that might help you with that is "Calculate Differences" from "Basic Mathematics" in ANALYSIS. That will give you an new channel with delta Y values.  You can then use the Calculator for calculations like squaring and taking the root.
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(3,891 Views)
I think the calculator is a good tool.  Too bad there is not a built in fuction, but the calculator will work just fine.  Thanks.
(3,872 Views)
