DIAdem
Convert angular rate
There is no angular rate defined in the DIAdem. My problem here is I want to add the deg/sec which was orginally obtain from data acqusition system to DIAdem then convert it into radians. What should I do? Thanks!!
(6,787 Views)
Hi cococrane,
You're right, deg/sec does not appear to be defined in the default unit catalog of DIAdem 2012 and earlier, and it should be.  The simplest thing would be to add the "deg/sec" unit to DIAdem's unit catalog yourself as a custom unit of the quantity angular velocity, along with the rad/s and 1/min units that do ship in the catalog.  Alternatively you could multiply your channel by 2*pi/60 with the standard scaling dialog in the ANALYSIS panel.
Brad Turpin
DIAdem Product Support Engineer
(6,772 Views)
Thanks!
(6,751 Views)
Hey cococrane,
Weird, today I looked again at a fresh DIAdem 2012 SP2 installation, and the deg/s unit was there.  I don't think it was added in SP1 or SP2, but it's definintely there in DIAdem 2012 SP2.
Brad Turpin
DIAdem Produuct Support Engineer
(6,449 Views)
Sorry about the weird name and icon-- not sure how that happened.
(6,427 Views)
