DIAdem
Copy part of channel data and paste into excel worksheet
  I want to copy part of channel data and paste into excel worksheet programmatically. I can copy data with "DataBlClpCopy" into clipboard, Does anybody can tell me what command I can use to paste data from clipboard into excel worksheet?
Thank you for your help!
GQ
(4,314 Views)
Hi GQ,
I'm not sure of the exact ActiveX shenanigans you'd need to pull to get the right active sheet, but... this looks like it would work: https://msdn.microsoft.com/en-us/vba/excel-vba/articles/worksheet-paste-method-excel
William R.
(4,287 Views)
Hi William,
It doesn't work.":=" in "Destination:=Worksheets("Sheet1").Range("D1")" is not recognized correctly in script.
GQ
(4,279 Views)
Accepted by gq
Hi GQ,
Try this.  It really does work.
Set Group = Data.Root.ActiveChannelGroup
Set myExcelApp = CreateObject("Excel.Application")
myExcelApp.Visible = true
myExcelApp.Workbooks.Add()
Set myWorksheet = myExcelApp.Activesheet
Set myRange = myWorksheet.Range("a1")
Set myRange = myRange.Resize(Group.Channels(1).Size, Group.Channels.Count)
myRange.Value = ChnToVariant(Group.Channels, "TransposedMatrix")
Set myExcelApp = Nothing
Brad Turpin
(4,274 Views)
Hi Brad,
it works great.
Let's go further, How can I copy part of channel data and paste to excel worksheet?
Thank you very much!
GQ
(4,263 Views)
Accepted by gq
Hi GQ,
You have two options.  You can fill the 2D array with values yourself, then pass that to the Excel range:
RowSize = 2
ColSize = 3
ReDim Values(RowSize-1, ColSize-1)
Values(0,0) = "0,0"
Values(0,1) = "0,1"
Values(0,2) = "0,2"
Values(1,0) = "1,0"
Values(1,1) = "1,1"
Values(1,2) = "1,2"
Set ExcelApp = CreateObject("Excel.Application")
Set Worksheet = ExcelApp.Activesheet
Set Range = Worksheet.Range("a1")
Set Range = Range.Resize(RowSize, ColSize)
Range.Value = Values
Set ExcelApp = Nothing
Or you can create a temporary Group of Channels that contain the desired subset using DataBlCopy():
Dim RawGroup, RawChannels
Set RawGroup = Data.Root.ChannelGroups(2)
Set RawChannels = Data.CreateElementList()
Call RawChannels.Add(RawGroup.Channels("Noise_2"))
Call RawChannels.Add(RawGroup.Channels("Noise_4"))
Call RawChannels.Add(RawGroup.Channels("Noise_5"))
Call ExportGroupBlock(RawGroup, RawChannels, 1000, 101000)
Sub ExportGroupBlock(RawGroup, RawChannels, iMin, iMax)
  Dim SelGroup, SelChannels
  Set SelGroup = Data.Root.ChannelGroups.Add("TempExportGroup")
  Set SelChannels = SelGroup.Channels
  FOR Each Channel In RawChannels
    Call SelChannels.Add(Channel.Name, Channel.DataType)
  NEXT ' Channel
  Call DataBlCopy(RawChannels, iMin, iMax-iMin+1, SelChannels)
  myExcelApp.Visible = TRUE
  Set myRange = myRange.Resize(SelGroup.Channels(1).Size, SelGroup.Channels.Count)
  myRange.Value = ChnToVariant(SelGroup.Channels, "TransposedMatrix")
  Call Data.Root.ChannelGroups.Remove(SelGroup.Name)
End Sub ' ExportGroupBlock()
Brad Turpin
(4,256 Views)
Hi Brad,
I really appreciate your help.
GQ
(4,251 Views)
