11-07-2017 06:56 AM
I want to copy part of channel data and paste into excel worksheet programmatically. I can copy data with "DataBlClpCopy" into clipboard, Does anybody can tell me what command I can use to paste data from clipboard into excel worksheet?
Thank you for your help!
GQ
Solved! Go to Solution.
11-08-2017 06:07 PM
Hi GQ,
I'm not sure of the exact ActiveX shenanigans you'd need to pull to get the right active sheet, but... this looks like it would work: https://msdn.microsoft.com/en-us/vba/excel-vba/articles/worksheet-paste-method-excel
11-09-2017 06:48 AM
Hi William,
It doesn't work.":=" in "Destination:=Worksheets("Sheet1").Range("D1")" is not recognized correctly in script.
GQ
11-09-2017 03:46 PM
Hi GQ,
Try this. It really does work.
Set Group = Data.Root.ActiveChannelGroup
Set myExcelApp = CreateObject("Excel.Application")
myExcelApp.Visible = true
myExcelApp.Workbooks.Add()
Set myWorksheet = myExcelApp.Activesheet
Set myRange = myWorksheet.Range("a1")
Set myRange = myRange.Resize(Group.Channels(1).Size, Group.Channels.Count)
myRange.Value = ChnToVariant(Group.Channels, "TransposedMatrix")
Set myExcelApp = Nothing
Brad Turpin
DIAdem Product Support Engineer
11-10-2017 07:15 AM
Hi Brad,
it works great.
Let's go further, How can I copy part of channel data and paste to excel worksheet?
Thank you very much!
GQ
11-10-2017 11:20 AM
Hi GQ,
You have two options. You can fill the 2D array with values yourself, then pass that to the Excel range:
RowSize = 2
ColSize = 3
ReDim Values(RowSize-1, ColSize-1)
Values(0,0) = "0,0"
Values(0,1) = "0,1"
Values(0,2) = "0,2"
Values(1,0) = "1,0"
Values(1,1) = "1,1"
Values(1,2) = "1,2"
Set ExcelApp = CreateObject("Excel.Application")
Set Worksheet = ExcelApp.Activesheet
Set Range = Worksheet.Range("a1")
Set Range = Range.Resize(RowSize, ColSize)
Range.Value = Values
Set ExcelApp = Nothing
Or you can create a temporary Group of Channels that contain the desired subset using DataBlCopy():
Dim RawGroup, RawChannels
Set RawGroup = Data.Root.ChannelGroups(2)
Set RawChannels = Data.CreateElementList()
Call RawChannels.Add(RawGroup.Channels("Noise_2"))
Call RawChannels.Add(RawGroup.Channels("Noise_4"))
Call RawChannels.Add(RawGroup.Channels("Noise_5"))
Call ExportGroupBlock(RawGroup, RawChannels, 1000, 101000)
Sub ExportGroupBlock(RawGroup, RawChannels, iMin, iMax)
Dim SelGroup, SelChannels
Set SelGroup = Data.Root.ChannelGroups.Add("TempExportGroup")
Set SelChannels = SelGroup.Channels
FOR Each Channel In RawChannels
Call SelChannels.Add(Channel.Name, Channel.DataType)
NEXT ' Channel
Call DataBlCopy(RawChannels, iMin, iMax-iMin+1, SelChannels)
myExcelApp.Visible = TRUE
Set myRange = myRange.Resize(SelGroup.Channels(1).Size, SelGroup.Channels.Count)
myRange.Value = ChnToVariant(SelGroup.Channels, "TransposedMatrix")
Call Data.Root.ChannelGroups.Remove(SelGroup.Name)
End Sub ' ExportGroupBlock()
Brad Turpin
11-10-2017 11:46 AM
Hi Brad,
I really appreciate your help.
GQ
