DIAdem
Copy paste issue in Diadem
Hi All,
Using Diadem 2020.
Currently facing copy paste issue in my layouts and script.
Example a newly created layout in which, like to copy and paste a particular table then getting the following error.
please guide me how to avoid this situation
(769 Views)
Hello Paul,
Do I understand correctly that you select a 2D table in REPORT, copy it via the clipboard and then when you paste it (CTRL + V) you get the error message?
When I perform these steps in the example REPORT layout or in a new layout, everything works fine for me in version 2020 SP1. There must be another circumstance that is causing the error. This can be a channel to be displayed in the table or a certain formatting of the table.
To be able to help you, it would be good if you write down your steps. Provide your layout and data via the forum post or create a new layout and use DIAdem sample data with which one can reproduce the error.
(747 Views)
