DIAdem
maximum values in TDMS channel
I have been experimenting with writing very large TDMS files using the TDM C DLL. I've been running into this error when trying to append values into a channel: "Error: The request would exceed the maximum number of data values for a channel." I was wondering if this maximum number in one channel is explicitly written anywhere, as I've only been able to find that a file can have infinite groups and a group can have infinite channels. If not, how could I tell that I'm about to exceed the maximum number and make a new channel / group to store my values?
Thanks!
(1,131 Views)
I guess the limit is in the index data types used by the file format i.e., U32.
https://www.ni.com/en/support/documentation/supplemental/06/the-ni-tdms-file-format.html
https://www.ni.com/en/support/documentation/supplemental/07/tdms-file-format-internal-structure.html
Santhosh
Soliton Technologies
(1,122 Views)
Could you elaborate more on what you mean by index data types? I'm not super familiar with how data types would affect the file. Thank you!
(1,115 Views)
Are you sure this is a U32?  When I drop down a TDMS Read the Index data type is an I64.  I assumed this meant it could address very large amounts of data per channel.  Admittedly I'm not sure I've ever logged over 4 billion values of anything to a TDMS file before.
(1,066 Views)
