DIAdem
Copying and Pasting Channels
When copying and pasting channels is there a way to leave out the name of the channel?  Whenever I copy and paste a channel into excel the name of the channel is always pasted with the data in the channel.
I just want to copy the data of the channel and leave out the name.
(4,193 Views)
Hmm. can you specify what you're doing exactly that's leading to that? It's not a problem I'm encountering.
Product Support Engineer
(4,173 Views)
Accepted by aGrimm
Hello!
This code does the job:
Option Explicit
Dim s
Call ChnClpCopy("1-4")
s = TextFromClipBoard()
s = Mid(s, InStr(s, vbCRLF)+2)
TextToClipboard( s )
You might add some code to make it bullet proof 😉
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,157 Views)
Works like a charm.
Thanks again Matthias.
(4,133 Views)
